- Jul 20, 2008
- 23
- 7
Ok well you have probably all seen my previous posts, but now i have come to a new problem.
I Wired up my amplifier and connected it to my headunit etc (the Amplifier works)
But, for some reason when i connect my Amplifier to the subwoofer, nothing happens and i have checked the setting and gain etc etc like i was advised and no noise at all.
Another problem i'm getting is that when i connect my speakers to the amplifer i get noise, just like a hissing noise, so power is going to them and when i adjust the power etc, it goes louder and quieter, but it's like its not getting the signal for the song :S
And my final point is that for some reason when i connected this up, the headunit started to get REALLY hot on the right-hand side and even the front speakers stopped working, even though i had not touched them at all. Obviously i turned it all off after this and disconnected the cable from the Battery.
When my Dad came round he said it could be a number of things, but obv didnt know without seeing, he said it could be shorting somewhere and could of possibly blown something somehwere or that it's wired wrong and it's over-heating, but the way i did it im SURE it's all wired up properly.
Could one problem be the wire im using? The speakers are 250 Watt's and im using that speaker wire to run the Amplifier to the speakers/The subwoofer.
Run-Down on the Equipment:
1000 Watt JBL sub-woofer. (Sure will sound amazing if i ever get it connected)
800 Watt Mutant Amp.
2, 6x9 Infinity 250 Watt speakers
My headunit is a JVC, no idea of the power output.
Thanks in advance, i really would like some advice on how to go about connecting it up properly and what i need to do so.
Hope i haven't wrecked my system!
~Morty.
~Morty.
