Bad Earth
Bad Earth
Oldham, manchester
I just picked up a car i bought a fiat bravo 1.6 16valve 100sx i wired my sub up yesterday and the sub only works now and again, wondering if it was a bad earth cos it worked fine in my other car, i currently have it earthed to one of the nuts on the rear lights, is there a better place to earth it and where do other people earth theirs to?
thanks in advance
Brooksy
thanks in advance
Brooksy
it might be if its painted were you are putting it on and its not making a good contact with the bodywork
its a bad earth, if u attached your earth to a painted part, then no it should theoretically not work. Where are you earthing from? There should be earthing points under your carpet in the boot, failing that just grind an area of paint away and you will be in business. :):)
Iv got both my earth in the same place and they work fine, you might wana try the amp?
