Removing bad sump
First drain engine oil by using allen key size 12
Remove all size 10 nuts/bolts from sump, since you will throw this sump away, for faster removal you can hammer a screwdriver in it and pull it down ( be careful not to stick it in where oil pickup strainer is- seen on pic named oil pick- left side ), you can also hammer a flat screw driver or wooden wedge in it and pry it away from engine block, again be careful not to damage the block
