getting too the mount and removal
Firstly open the bonnet to give you some natural light (it all helps)
The easiest way i find to get the the mount without blocking your access is to have the front two wheels on the kerb with the car in gear, handbrake on if it works and the rear wheels chocked
Or you can jack the car up from the front wishbone Where it mounts to the chassis and use the axle stand on secure place on the chassis
This is a shot mount that i was working with
You should be a jack under you engine sump with a plank of wood just encase your other mounts arn't that good to stop it from killing them (you will have to raise and lower the jack while removing and fitting the mount)
You will want to remove the two bolts (13mm) that hold the mount to the chassis
With those two bolts removed the engine should tilt forwards a bit showing the top of the nut/bolt combination
Now put a 17mm spanner over the top nut/bolt (depends with way it is for you) and the 17mm Socket on the end and undo them
remove the old mount along with the nut, bolt and washers
This is what the old mount was like, it tried to suck itself out
