Wiring RCA's and Remote
STAGE 3
RCA Cables
First of all you need to remove your headunit. Do this with the keys supplied with the stereo.
You then want to feed the RCA cables down the back of the headunit towards the drivers side of the car.
You then need to pull the RCA's down so that only a little bit is left at the headunit gap which can be plugged in. Push the RCA cables down the carpit collumn on the right by the door and repeat the stages of the power wiring from the plastic footwell on the floor until the RCA's are in the boot.
While doing the RCA's you should also run the remote cable down the with them as that also needs wiring and it saves you doing 2 jobs seperate.
