so lets remove the badges
right i recommend you focus on one badge at a time here untill they are all removed.
so apply a little heat to the badge,if using a heat gun be careful not to overheat the paint!
if you are using hot water then just pour it over the badge and give it a few seconds for the heat to transfer to the badges glue.
then work under the badge with whatever you are using eg fishing line,credit card etc and work along the glue.
do not use anything that will damage the paint such as a metal impliment
if it gets hard to reove the badge as you work along,just apply heat again and repeat the process
