Soledering the new plugs to the existing cables
I started at the left side.
Cut of the first cable and strip the end.
Also strip the end of the cable that has to be soldered to it.
Put some heatshrink over the cable and twist the two ends together.
Solder them with a bit of solder so it has a smooth finish.
Pu the cloth undearneath it so no solder can damage your paint.
Left side:
Rights side:
These cables must be soldered together:
Left side:
Orginal cable -> EVO cable
Black/White -> Black
Red/Yellow -> Red/Yellow
Orange/Black -> Blue/White
Gray/Black -> Green/White
Right side:
Original cable -> EVO cable
Green/Black -> Black
Gray/Red -> Green/Yellow
Orange/Black 1st pin -> Black/Yellow
Orange/Black 2nd pin -> Blue/Black
Once soldered together plug in the new EVO light to check you work!
My cables were long enough to put the ligth inside the car so I could see if everyting worked.
Turn on the light, turn signals and the brake light.
If everything works put the heatshrink in place and shrink it with the lighter.
Ignore the faulty light error on the dash
Results:
