Downloading & Burning 244/250 eLearn ISO CD image
I have just copied this from its earlier position in the Miscellaneous Section to make it easier to find & added a link for the X250 eLearn zip file.
Here are the links I have put up over time as to how to download & burn the eLearn ISO "image" to CD
https://www.fiatforum.com/ducato/312994-ducato-2003-2-8-jtd-manual.html
https://www.fiatforum.com/ducato/241490-ducato-wiring-diagram.html#post3157060
https://www.fiatforum.com/ducato/299299-downloaded-manual.html
But better still here is a step by step guide using 2 different methods.
Downloading & Burning 244 eLearn ISO CD image
Step 1 Download the Ducato eLearn 02-06 RAR file containing the ISO image. - 113 MB
Which can be downloaded as one complete RAR file from this link here -
https://www.filefactory.com/file/5s...le_Tecnico_D_officina_-_Fiat_Ducato_02-06.rar
go to bottom of the page & select slow download wait till countdown then click "Start Download"
Step 2 download Winrar from the web, it is free - here are 2 places - http://winrar.en.softonic.com/download or http://filehippo.com/download_winrar_32/
Step 3 When the eLearn RAR file has finished downloading (make sure you know where it went on you system) & you have installed Winrar on your system. Winrar is not the only program that will open RAR files Winzip, 7zip & a lot of other compression programs will open RAR files as well.
Step 4 Using Winrar as the example , when you double click on the downloaded RAR file linked above in step 1 containing the eLearn CD image it will open to reveal the RAR has 1 file inside it – the eLearn ISO, on the menu at the top of the winrar program there is an “exract to” button, highlight the 1 file as in - eLearn Manuale Technico D’officina Fiat Ducato.ISO
Step 5 When selecting the “extract to Button” it will give you an option as to where to extract the file to, so select where you want to extract the file to, this will give the ISO file from which you can then burn the ISO image (567 MB) to a CD
Step 6 Once you have the elearn ISO you then need a image burning program such Nero to the burn the ISO as an image to the CD. As there are so many burning programs available I cannot not go into how to do this for all programs..
Using Nero Burning Rom version 8.3.1.6 – when in the new compilation window select CD (not DVD) then at the top of the list use CD-ROM (ISO) then click open & navigate to where you extracted the ISO image to & select it, put Ducato eLearn in the Disc name under label tab, then select burning speed etc & click “Burn”. This will, if all went well produce the eLearn CD which you can then use to install the program on your system.
Step 7 When you have the completed CD image burn, you can remove it from the drive then reinsert it in the CD drive & if autorun is enabled on your system it should start to install itself automatically & add the eLearn icon to your desktop, NB: the CD must be in the CD drive whilst using the program for the installation files on you system to access the Databases on the CD, so when using the program first put the CD in the drive.
There are also other methods of running the program such as mounting the ISO as a virtual drive using such programs as Daemon Tools etc.
Although it is not obvious the eLearn program uses Internet Explorer as its interface & will not work with any other browser. From my experience the latest version of I.E. I have on Windows 7 is I.E.11 & it operates with no problems on that, (& previous versions back to IE6) & windows XP, should work on Vista as well, on saying that I will try it on Windows 8.1 also with I.E. 11 & see what happens.
To make it slightly easier for those who aren’t computer literate I have devised an alternative method of making the eLearn CD using Winzip as follows.
Downloading & Burning 244/250 eLearn CD using Winzip
Make a Directory on your system & call it whatever, maybe Ducato (Note: not eLearn as that is created when installing the program) then download the 244 zip file (163MB) from here –
https://www.filefactory.com/file/rc3khd8xb43/244Ducato_eLearn.zip
X250 Model from here -
https://www.filefactory.com/file/cj9qazzpsox/X250.zip
Save the X244 or X250 zip file to a directory where you can find it.
Once you have downloaded the zip file open the 244Ducato_elearn.zip or the X250.zip & extract the contents of the zip file to your newly created directory.
For the 244 In your directory you will see a Directory- “folder” called 244Ducato_eLearn. For X250 it will contain files/folders as listed below.
From one of my previous posts - the contents of which should look like this –
the folder contents should be as below with 5 folders (in red) plus 5 files in the root directory of the CD (the contents of the above eLearn ISO should look the same)
Database
pdf
svg
system
autorun.inf
elearn.ico
ex_setup.exe
setup.exe
start.exe
Now all you need to do is burn the contents as in the 5 folders & 5 files above in the “244Ducato_eLearn “ or X250 Version folder to a CD. This will create an eLearn CD which can then be installed on your system & again as stated above the CD has to be in the CD drive when using the program.
As above if autorun is configured on your system once the files have been burnt to the CD & it has completed open the CD drive then close it again & it should start the install automatically. Also once it is installed on your system just putting the eLearn CD in the drive usually automatically starts the program without clicking on the icon the installation puts on the desktop.
Not “quite” as complicated as the ISO.
When you start the program select the language in the top left - english then select the engine size. Then click on the X244 Blue Ducato van at the top or silver X250 & select from the menu on the left.
This ISO guide applies to all versions of the eLearn so it is the same for Ducato, Stillo, Panda etc but not the Winzip method as it only has the 244 Ducato CD version in the zip file.
The eLearn program is basically the same as any Windows software program, once you have the elearn CD it installs just like any other program & accesses the info from the database on the CD which is why it needs to be in the drive when using the program but only runs on/needs internet Explorer.
The complicated part is in the version on the forum the ISO has been split into 5 parts to make it easier to download. When you have all 5 RAR parts downloaded & use winrar to extract it out it looks for the “other” 4 parts of the RAR file & extracts it out using the 5 parts into the eLearn ISO which is then burnt to CD. The first link at the top of the post is the same eLearn RAR as the on forum but is one big RAR file instead of being split into 5 parts as in the forum version.
An ISO file is an image of a CD which when burnt to a CD produces a copy of the original CD & is used to enable exact copies of CD/DVDs to be transferred over the internet.
I have just tried the older DTE version on I.E. 8 on XP & it still seems to work OK but did have problems with the wiring diagrams so maybe the SVG viewer needs to be installed ? Might just post this as a separate thread & in the Guides section so it is easier to find.
Hope that is clear enough to follow & helps – any problems just ask
Database
svg
system
autorun.inf
elearn.ico
ex_setup.exe
setup.exe
start.exe
Downloading & Burning 244/250 eLearn ISO CD image updated links
Hi All
here are some updated links to the elearn files -
X244 eLearn zip - https://www.filefactory.com/file/610qbesgtnui/X244Ducato_eLearn.zip
X250 zip- https://www.filefactory.com/file/3b0kddvofax4/X250.zip
eLearn_manual_techico_D_officina_Fiat_Ducato_X250.rar - https://www.filefactory.com/file/21...ale_Tecnico_D_officina_-_Fiat_Ducato_X250.rar
Talbot_express_van_92-94.zip - https://www.filefactory.com/file/3zv7sv7swd2a/talbot_express_van_1982-1994.zip
