Removal
Make a bracket to fit the engine block.
Make a engine support crossbeam to hold the engine in place when the mounts are removed.
I made this out of a scaffolding board, angle iron , screwed rod, steel plate, etc.
Once fitted and any wiring, gear cable, clutch cable and reaction strut are disconnected, the gearbox mounts can be removed.
You can now pull the engine forward so that the bottom radiator hose is touching the fan. This is a must or you cannot remove or replace the gearbox.
Place the jack under the gearbox and remove the 6 bolts from the bell housing, prise the gearbox off and lower to the ground.
