Removing / Changing Battery
So if you just want to change the battery you've got it easy.
Open the key blade out.
Take a look at the standard blue key and you'll see it has a little flat point screw made out with an arrow pattern on top.
On the key fob itself it's marked with a locked and unlocked padlock symbol. Rotate the screw 45 deg to the unlocked padlock. Don't force it to go further or turn the wrong way!
Place your screw driver under the end of the battery holder just next to the screw and lever against the blade to pop the end of the battery tray up.
Then it's a simple case of sliding the old battery out of the tray with your finger nail and popping in the new one.
If you're changing fob case go to next page.
To replace - hook the non-screw end into the fob and then push down on the screw end. Obviously return the screw to locked position.
