Removing
- Position the vehicle on a lift.
- Remove right front wheel
- Remove right front wheel arch liner
Photo 1 - Loosen the band and disconnect the turbocharger air supply hose, air filter side.
Photo 2 - Undo the bolt (1a) and remove the air filter assembly (1b).
Photo 3 - Remove the O-ring from the cold air intake pipe.
Refitting
- Fit a new O-ring on the cold air intake pipe.
- Place the air filter assembly in position and tighten the bolt.
- Tighten the band securing the air supply hose to the turbocharger, air filter side.
- Fit right front wheel arch liner
- Remove the vehicle from the lift.
