THE REPLACEMENT
The OCS sensor is integral with the seat base cushion so the whole lot is replaced as one although, the OCS is just stuck on the cushion with glue so it’s a bit of a con.
It may be worth testing that this is actually going to cure the fault by placing the new one on top the seat and connect it via the grey connector. Turn the engine on and sit on the seat plus new cushion. No beeps or warning lights now? OK that’s it then- time for action
THE JOB
Choose a place where you can open the passenger door to it’s widest point for access as you’ll want room to move the seat base out the door or (your choice) you could remove the whole seat to a workshop
