Archieleggatt
- May 13, 2006
- 96
- 15
Got my car back from the Fiat Garage today and this is what they said. There are two rubber grommets, at the bottom and either side of the boot lid. They are designed as drain holes, also there are two holes towards the middle of the boot lid as well...also drain holes. I was told that the boot lid is made of two pieces of metal shaped and welded together. If this seam of the weld is not quite water tight then water could get in and run in to the skin of the boot and out of the drain holes. Sounds odd to me but there you go! Also, they wasn't sure if water could be getting in to the third rear brake light as it dosent seem to have a seal around it. Fiat put some sealent around the edge of the third brake light and put it back in place. (Great! So what happens when i wanna get if off and change the bulb???) Hasn't rained or haven't had a chance yet to test if this has fixed the problem or not. SO...all in all i conclude that Fiat have no idea what the deal is. ALSO they seem to have no idea where the water could be getting in....despite having the car all day today to find that out! Now, ive had plenty of diferent models and makes of cars and this is the first one to have water get in to the skin of the vehicle and piff out of the corners of the boot lid when you open the boot. Stand in the wrong place and you get a steady stream of water over you!! Now either there is a genuine problem and this is not supposed to happen and the grommets are not drain holes OR this is supposed to happen (As fiat tell me...truth or not??) and the car is designed to piff all over the owner when opening the boot after a light rain fall...could Fiat REALY have designed a car this way?!?!?:bang:
See my earlier reply that led me to this same conclusion. I've now had another look and......
the two rubber grommets appear to be threaded - my left hand one was tight - the right one ( which had spilled rainwater on opening the hatch lid, is now tight too ) .
Jsut got to wait for rain now and open the boot lid to see if it's cured it by forcing the rain water that passes through the skin down and out through the two lowest visible central drain holes whilst the hatch is closed!
A strange way to make a boot lid tho IMHO. But then it is FIAT.
