Re: First to second gear
Here's the list of problems summarised that I'll be handing to the dealer today (for those who are interested):
Dear Fiat service team,
Please see below the list of current outstanding issues with xxxxxx.
Juddering Dualogic
There is a violent juddering/jerk when pulling away from first to second gear in either auto or manual mode. This happens when the car has been left cold (i.e. undriven) for about two days and goes away after about 20 to 30 minutes of driving. So please do not start work on the car until Thursday (22nd) at the earliest.
Your team has already looked at this issue at the end of December 06 and the gearbox has been recalibrated – which did not help. Previously it took a week before the problem occurs, but now it only takes about two days so I’m assuming the problem is getting worse. The symptoms it displays suggests that something is not warmed up (e.g. clutch plates, transmission oil etc) because the problem disappears after the car has been warmed up after 20 to 30 minutes of driving.
Reverse gear clank/grind
Also not sure if this is related to the above, but occasionally when the reverse gear is selected it makes an extremely loud grinding noise. Not sure if you can replicate the problem as it occurs quite randomly, but it would be greatly appreciated if you could look into this when dealing with the above issue.
Dash vent demister
The dash vent demister (driver’s side) has popped up and now no longer sits properly in place. This was already replaced once at the end of December 06, but a few weeks ago it had popped out of place by itself for no apparent reason.
Steering wheel clicking
Steering wheel makes clicking noises and thuds when turned either to the left or right. Again your team looked this at the end of December 06, in which I was advised it was due to a loose knuckle, which had since been tightened – again this has not resolved the problem.
Dent on hatch lid
There is a small dent of the hatch lid (right hand side towards the middle). Although shallow it is definitely noticeable. Do you provide paintless dent removal services or would you be able to refer me to someone that does?
Dualogic manual
I was not given a copy of this at the time I purchased the car and I’ve been trying to get my hands on a copy for months now. Fiat Australia has provided me with a parts number 60346822 - would you be able to provide me with a copy of this please?
Should you need clarification on any of the above issues please feel free to contact me on xxxx xxx xxx.
Thank you and Best Regards,
Kevin
But I've being booked in for the coming Monday anyway - its better than just sitting here and wait, right?
Juddering Dualogic
Dash vent demister
Dent on hatch lid
Dualogic manual
Kevin
