Old 28-10-2006   #1
Moderator
Andy Monty's Avatar
Andy Monty has donated!
Who makes Front fog lamps to fit GP?
I want to fit a set of front fogs to my GP active.. I work in the middle of the countryside and the road suffers from thick fog on a regular basis...
My dealer had given me a rough price for 100 for a pair!
NOT including fitting. (I'm OK with wiring would fit a switching relay and would probably take the switch (side light) feed from the 7way bypass tow-bar relay and the suppy fused down directly from the battery to avoid warranty issues etc) I have the black plastic blanks in the bumper i assume its a simple matter of unclipping the blanks and popping in the fogs ?
Who makes the Fogs? I managed in the past to save 20 on a replacement headlamp for my Ford KA from a Velco dealer rather than ford.
Any help great-fully received
thanks
Old 28-10-2006   #2
Moderator
ChrisUK's Avatar
Trader Rating: 1
ChrisUK has donated!
Bartender Champion, Wood Firing Champion
Re: Who makes Front fog lamps to fit GP?
Bosch I think..... I had to take them out my bumper when I sprayed it. There is two bolts holding in the fog lamp. One is underneath the bumper and one is under the fold above where the fog lamp goes. If I where you I would buy them from dealer and fit yourself and you should get the right bolts etc.
ChrisUK is offline Reply With Quote Quote
Old 10-12-2006   #3
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by ChrisUK
Nerd alert!.....3 bolts actually
Agree,get lights from dealer (& fitting bolts) ...then use standard 4-pin relay with a internal switch on sidelight supply.I normally mount switch in centre consul as looks quite neat there especially using a black small switch with red LED on light
Old 10-12-2006   #4
y is saving so difficult?
jamesgamby1989 has donated!
Cool Re: Who makes Front fog lamps to fit GP?
i was also wondering how much they would be for my active, do you reckon they would charge much more for fitting as i would not trust myself to fit them??
1.2 gp, chemical grey, all windows tinted, alpine headunit, fusion woofers, vibe tweeters, interior neons, xenon bulbs, blue sidelights, rainbow indicators, momo handbrake, induction kit, debadged boot, sony xplod sub and amp,personalised number plate, momo gear knob, punto black side stripes first in world, black lexus lights
K+ N INDUCTION KIT FOR SALE
jamesgamby1989 is offline Reply With Quote Quote
Old 10-12-2006   #5
Forum Moderator
T14086's Avatar
T14086 has donated!
Fitting would be expensive as you have to fit switch,fit fuses/relay,run wires to lights/through bulkhead etc.Took me 3 hours from start to finish but i'm kinda fussy and heatshrink connections,cable tie wires out of view etc.
Old 10-02-2007   #6
jawkithenoo has donated!
AirFox Champion, Sub Commander Champion
was quoted 190 supply and fit from fiat dealer. They had to pick me up
jawkithenoo is offline Reply With Quote Quote
Old 10-02-2007   #7
Forum Moderator
T14086's Avatar
T14086 has donated!
Quote Originally Posted by jawkithenoo View Post
Not too bad actually as I think the lights (and fitments) are arouond 120.
Die Hard!!! The Negotiator Leisure Lounge 27 24-04-2006 22:20
Ring Deluxe LED Cruise-Lite - Fog Lamps / Lights phatbenny Auction Watch 0 02-06-2005 17:09
(S) what makes of 4studed car's (vauxhall ect...) alloys fit on seicento? gazzaman2k Cinquecento / Seicento 6 13-04-2005 06:28
(T) Changing front suspension arm bushes(change to guide format) peaster2k Cinquecento / Seicento 2 21-02-2005 18:57
(S) Front fog lights on Uno 45 uno_man Uno 2 29-11-2002 00:53
