Look like your wish has come true....The 1.6Mjt from the Bravo for the GP is something i'm keeping my eye on!
I'm picking mine up in September (allegedly, so says the dealer).
Well I have a real mix of diesel power [ wifes a 90hp + tuning box = 110hp?, mines a 210hp Seat leon fr MK2] the Leon behaves like a petrol engine but the Fiat 1.3 behaves like a like a slug below 2.5k then its off like a rocket!! - with a very small power band. Looking at the charge air plumbing it needs to be much shorter?. I was hoping on this web site some chaps might have found a alternative charge cooler with shorter connection pipes. And diesel do need to have high miles before they give their best - And both have the cursed DPF which makes them use more fuel!?!?@!There is not much to choose betwee the mj90 and the 1.4 sporting as it is so wouldn't take much to make it quicker. The aftermarket remap guys can get 120 bhp and 265nm torque easily out of the mj 90 as it is
What I don't fully understand is that if the particulate filter is suppose to *prevent* sooty exhaust, why does it then 'purge' the DPF? Doesn't this mean you just create a mini smog area every few hundred miles instead of a faint smog trail continuously as you drive?
Ah, that would explain the forest fires then!It doesn't purge them it incinerates them at 600oC
