Also to fit them you have to completely cut the entire hinge, inner wing and door to pieces. Weld bits of steel on and generally completely **** the car over. There's no going back. Which is bad because the gas struts on them usually fail and they are so flimsy that the door will probably blow off in the wind if you aren't careful.
