I dont own a Grande Punto but have herd there is a fault with the radiator fans motors not swiching on and off propley when engines over temp
ELTSBABY said:I dont own a Grande Punto but have herd there is a fault with the radiator fans motors not swiching on and off propley when engines over temp
T14086 said:Well I work behind those closed doors & I have never heard of this fault,either from personal experience,from other technicians,from technical seminars,from Fiat field engineers or from Fiat technical department!
I certainly can't fault my dealer, he has been faultless, it's the sub standard product that's the problem.Steve_R said:3000 miles in, and the drivers door lock mechanism broke, so the door wouldnt stay shut (luckily it happened at home). Called the AA out, and they managed to bodge it shut so I could drive it to the dealer. Lock replaced under warranty, and all back to normal now.
Excellent service from the dealer, which I wasnt expecting after reading all the reports etc......
Steve_R said:Excellent service from the dealer, which I wasnt expecting after reading all the reports etc......
NumanR said:No cases of fans failing on Grande, I had a meeting with the top dealers in the south of england earlier this month and no cases were raised, and no information from Fiat and also no request from Fiat to monitor fan problems.
So I would say there was no problem.
Sporty said:Only one small problem so far (1500 km)....(one clip missing from the plastic inside the rear wheel arch...)
