Technical Rear Lights prob-NOT lamps or plugs
alfistiUK
I'm getting slight cross contamination between tail lights and indicators on both rear lights.
I have eliminated the lamp units (by removing them) and the plastic plugs and the earth is perfect.
Putting a multimeter on the plug supply wires shows that the problem must be further back/ supply- electronic module???
TESTING ON OFFSIDE=
With brake on -Green/yellow wire (brake wire) ONLY 6.7v
Lights on- Yellow/black (tail light wire) 11.7V and green/yellow wire 6v
Indicator on- Blue wire (indic wire) 11.79v AND green yellow wire 5.7v- WHICH MUST BE INCORRECT.
Car battery is good- no problem starting up etc, and test results the same with engine running.
Any ideas?
Many thanks,
John
Not sure.
I ran an separate 'good' earth from the boot catch to the multi-meter and got the same results.
