Technical Part number for brake booster vacuum pipe?
Insanity
Member
Hello guys, the brake booster vacuum line on my 90hp 1.3 mjt punto is cracked on both ends but I can't find a replacement anywhere! Do you guys have the part number? Perhaps anyone knows the inner and outer diameter so I can buy a silicone hose to replace it with?
The parts catalogue shows 9 different part numbers for the left hand drive Grande Punto vacuum pipe.
If you want to send me your VIN by private message (PM) I may be able to get correct part number for your car.
According to the parts catalogue and your VIN, the part number for the vacuum pipe for your car is 55703046 if you have the 5 speed gearbox, or 51785737 if you have the 6 speed gearbox.
Insanity said:
I tried using a flexible pipe but it sucked the hell out of it, so I don't think there's a workaround, I'll have to find the part.
To stop an ordinary piece of pipe from being sucked in or collapsing, put a spring inside it.
Kali tichi.
