Technical Punto sporting t-jet rough idle and lack of power
Scunnychris75
Snitterby
Hi. My punto had just decided to start idling really roughly and had had no power. As I accelerate it kind of jerks, smooths out at 3000 rpm ish but has no power. I already changed the plugs, coil packs and lambda sensor, local fiat dealer was no help as it’s not storing a fault
Lots of threads about the same subject on these forums, so have a look to get some idea.
My thoughts
  • Air leaks : pcv hoses ?
  • exhaust manifold gasket leak? broken studs?
  • fuel trims?
  • blocked exhaust ? catalyst ? mufflers?
Also map/ maf sensor, give them a good clean.
Buy only original Bosch map sensor. Any other brand will put your car into limp mode. Your car also has MAF sensor, i believe.
