My 2008 1.2 Grande Punto runs fine until the RH indicator is on (or hazards), then the fuel pump pulses on / off in unison with the indicators. This then brings a 'starter relay' fault up.
I have looked at wiring and grounding in the engine bay, checked all light clusters and tried removing all indicator bulbs but this makes it worse as the relay pulses faster and the car stalls and will not run.
Is the indicator relay part of the BSI module? Is it feasible with basic soldering skills to replace the relay assuming it is at fault?
Any advice appreciated. Thanks.
