Hello again.
I've had a long running issue that I'm hoping you can help to shed some light on for me.
A while ago, the car started taking 4, 5, 6+ times to start, then once it had started would run well enough.
Got an engine warning light, got it hooked up to a computer and the code came up as a Coolant Temperature Warning, so had that part replaced.
A short while later the same error code came up, and the engine continued to take a few attempts to start.
On occasion the temp dial in the dash wont work, but it starts working again next time I use the car.
My friend, who is a car mechanic suggests it could be the MAP sensor, but before I buy the sensor I'd just like to your ideas.
Thank you.
Thank you.
