Technical Cruise Control on 6th Gear
karimalaa
Hello,
I have a small issue, i have '10 grande punto 1.4L 8V emotion
it is factory fitted with cruise control and 5-speed manual.
I swapped the gearbox for a 6-speed manual. everything working properly "same driveshafts, same clutch kit, same inner and outer forks, same clutch master cylinder, same mountings"
But cruise control not operating on the 6th gear. It only works on 3rd,4th or 5th gear.
I believe that the ECM does not recognize the engine speed/wheel speed on the 6th gear.
Is there any way to configure the ECM on 6-speed gear instead of 5 or any other solution?
Thanks in advance.
