irishblood
- Jan 18, 2021
- 2
- 1
I have a friend with a 2006 GP (199) 1.2 8v , with a few problems:
1/.The headlights often don't turn off, as there's no water in the fusebox, I 'm guessing its the combination switch, but the s/h ones often come with a warning that they might need coding to fit the car. Is this the case?, & what is involved?
2/. Neither rear door will open properly from inside or outside. It appears to be the locks, are replacement locks from other Punto models compatible?
3/. This one really stumps me - Yesterday the engine would no longer turn off - turn off the key, &remove it, the dashboard etc goes off s it should, but then engine keeps running, properly. (not 'running-on' because of burnt valves or anything dire like that). Any clues for this one??
Many thanks in advance.
