Hello,
I have a 57 plate 1.2 active grande punto.
I've been having problems with a cold start up as previously described by others on this forum, I have since had a new battery and this is testing fine.
The Car has been starting and cutting out and taking multiple times to start, however once it has started it runs fine.
The engine management light has also become lit up on the dashboard.
i have read from numerous threads that this is likely the MAP sensor.
I was wondering whether this is easy for a rookie to clean, or whether it is best to take it to a garage.
I have read on threads that when you take it to the garage they tend to change the coolant temperature sensor, as this is what the code reader brings up, however this doesn't solve the issue.
