General Punto grande automatic electrical issue
Cally59
Punto grande automatic: whenever it rains heavily the car keeps cutting out, the dashboard lights all flash and the gearbox flips to neutral. After a few minutes it runs again. Gearbox checked out OK. Where is the most likely place for water getting in? Help?
Hi
2 obvious leak paths are above :)
Remove the fusebox cover.. blow over with a hairdryer for a few minutes..
Then CAREFULLY replace the lid.. they are often fitted badly :eek:
The scuttle drains are little rubber hoses
If car is often parked under trees.. leaves with get in the scuttle and rot down to fill the tubes.. then resembling a 'plant pot' :(
Search DUCKBILL on here ;)
