Jordanirutter
- Sep 26, 2020
- 9
- 1
Hi guys my dualogic won’t select auto, drives perfect in manual. Any advice would be great as can’t find anything on it
Nobody’s knows then
I used a foxwell to read it I also had faults for p0500 vehicle speed signal brake node. And p0710 temperature. I removed the battery checked and there are no leaks whatsoever. Put all back together and cleared the faults and now it’s working again but feel like it’s just going to do it again
There is a depressurising procedure to check the level, and I would advise against just adding fluid. If there is definitely no leak then leave it alone.The fluid in the pump is on the minimum mark do I need to add more? Could this be the issue?
And which one is the vehicle speed sensor because that is the fault that says brake node
