Spanner109
- Jun 30, 2020
- 4
- 2
Hi All
My daughters (82k miles) 2006 Grande Punto 1.2 is driving me mad.
The car runs like a Swiss watch it starts on the button you can take it out for a drive (30 + Miles) and it is faultless until you go to slow down for a junction or park and the revs drop to just above idle the the engine just stops dead there is no juddering, the engine just stops dead, some times the engine will start straight back up and other it will take a little throttle action. After it has cut out you can leave the car running while parked up and it will run for a while and then just stop, it can run for 15 min or less before it stops.
There are no engine fault codes showing when I scan with multiEUscan.
Parts that have been replaced in the great fault hunt so far:
Coil pack, leads and plugs
Crank shaft sensor
Throttle body
Map Sensor
Vacuum hoses checked and are ok
all earthing points cleaned
After replacing each of the items above the car always gave the same symptom/fault. with no stored error codes.
My next may be the fuel pump... meh!
Any help or pointers would be greatly appreciated.
Crank shaft sensor
Throttle body
Map Sensor
