Compax
Member
- Sep 15, 2019
- 61
- 87
Wow this is crazy , sympathies.
Are your new pads rubbing full area of disc?Or is it the same as before? Did you measure the new pads before giving them to garage and did measurements match up with brembo drawings?
When you looked at scrap yard car were the pads rubbing the full area of disc?
If yes get the calipers ,pads , pads carriers and discs off that car. Take all those parts to your garage , ask them to see if they are any different to parts on your car already.
It doesn't matter if the pads and discs are rubbish just need them to identify what is wrong.
€30 for a knuckle is very good value so they might do the knuckle with the brakes still bolted on very cheap too.
Please can we have a pic of your disc taken through the wheel with new pads fitted.
Cheers Jack
Hey Jack,
I think you misunderstood. I did not get a new set of pads on the car, as the garage told they were identical, and the only difference was another wear sensor.
The one junkyard I went to only had the knuckle and caliper from the car, but nothing else.
Another junkyard does have two standing, but have not dropped by them yet, as I simply have not had time.
