Hi Guys,
Recently bought an MK3 fiat punto grande 1.4L petrol non-turbo and really liking it so far!
There is one issue I have noticed daily which is cold-starting or starting in general where the car will start up fine, but reaches resting revs and then cuts out a few times (feels electronically controlled through ECU, not an engine failure, battery/alternator as had these issues before on other cars)
Took it to the garage and diagnostic gave faulty temperature sensor reading. The temperature sensor was replaced and the problem is still there, hopefully this may improve with time?
The garage said to do an ECU reset but I am tempted first to adjust ever so slightly the idle revs. Does anyone know where the screw to adjust this and if it is a good idea on this car? Was planning to just experiment a little and see if any difference, thanks in advance
