Hi Guys,
Recently bought a used fiat punto grande 1.4L that has low mileage (36k miles), as he owners grandad only used it occasionally. The car had hardly been used so the owner jump started it and drove it for 3hrs home with no issues after that.
When using the car at home noticed that it required anywhere from 2-6 tries to start the engine; it would start engine every time but when reaching resting revs the engine would cut out.
I took it to an MOT garage who ran diagnostic and said engine temp was coming up, also noticed that the coolant level was sitting ever so slightly below the minimum level. I boiled and cooled ~300mL water (to remove impurities) and topped up to the max level (may be a tad over).
The car then started first time, next morning needed 5/6 tries, then I opened and closed the coolant cap coming back from work on 3rd trip (no liquid added or taken) and it started first time.
There seems to be a link between opening and closing coolant and it starting first time. Although, when at home I do park on a curb so maybe the sensor misreads the coolant level and relays back to CPU, OR maybe the temperature sensor is just malfunctioning altogether?
I have done a quick earthing test, no issue there as same result. The alternator has also been changed so doubt this is the issue.
If anyone can shed any light I would be really grateful, thank you. Otherwise seems a great car to drive etc.
