Technical Helpppp Air circulation and air conditioning button do not work
aytugozcan
hello friends Grande Punto 2006 I press the air conditioner key and the air circulation key in my car and it is not working lights are checked fuses are checked but somehow it doesn't work how can I go Google translate I'm translating I'm sorry for sentence mistakes
It seems that both keys are powered by the same relay (T6). Have a look at the diagrams.
Her iki tuşa da aynı röle (T6) tarafından güç verildiği anlaşılıyor. Diyagramlara bir göz atın.
BRs, Bernie
Hello, has anyone managed to solve this problem, i have the same problem as you.
Have you taken the controls out and checked the connections on the back, most of these buttons are soft touch and the Ecu does the control it just knows you’ve pressed the button and electronically and separately a switches on the function, if the button and the light is not working at all I’d wonder if the controls themselves have a broken internal track or wire.
Thanks Andy for your reply, is this easy to fix?
