General Rear Door lock
Litesnip
I have a Grande Punto 1.2 8v, it’s a 5 door and I’ve got the following problem I hope somebody has the answer for or has experienced the same issue,
When I unlock the car the N/S/R door won’t open from the outside, You have to open it from the inside first, then the outside handle will work until you lock and unlock the car again, Is this a common fault or know issue
