FIAT Auto Specialist Team
Old 30-11-2019   #1
Fiat grande punto 2008 1.4 Battery / alternator / Power steering problem
Hiya I often have a problem with power steering when first starting my car but when I turn the key off and back on again power steering always comes on second time round.
Anyway today I just came off the motorway and onto a 30mph road, music blasting when my power steering went while driving. I carried on and my abs light came on. Pulled over. Switched ignition off and tried to start car again, wouldn't start. Waited a few minutes, tried again car started, no power steering though. Got it home. Tried to start it again wouldn't start at all, I jump started it and car started with no power steering. Switched ignition off and car wouldn't start.
Anyone encountered anything similar and what was the problem?
Thanks. Stacey.
Stace777 is offline Reply With Quote Quote
Old 30-11-2019   #2
Vatican City
Exclamation Re: Fiat grande punto 2008 1.4 Battery / alternator / Power steering problem
No, you are the first one ever. Or it's a very rare, special-snowflake case. There's no hope. Look for a new car.
Lame jokes aside. This is very common (standard) problem. Electrical stuff. Cables ("earthing points"), connections, fuse box rotten, alternator soaked in water (or cracked), therefore battery went bad, etc.
SEARCH the forum (Forums and Guides section). Multiple threads (with solutions) are there.
PS
Mine did almost the same things last winter, but I didn't asked (because there was no need - answers are there).
GrandePunto PL is offline Reply With Quote Quote
Old 01-12-2019   #3
nikrox has donated!
Smile Re: Fiat grande punto 2008 1.4 Battery / alternator / Power steering problem
Welcome to the forum.
Feel free to ask any questions you want or need to.
This forum,like many others, has various sections,guides and answers to just about any questions you can ask.
There are common faults to these cars,hence the guides,and even when you've looked at the guides,the responses to questions following the guides often example how we problem solve issues.Were not all the same and learn differently.
Take some time using the search function...its your new best friend..
Likes Pugglt Auld Jock liked this post
nikrox is offline Reply With Quote Quote
Old 01-12-2019   #4
Belgium
Ground ground ground ...
Old 01-12-2019   #5
Thanks for the replies I guess... I have searched the forums and the Internet but wanted an answer more specific to my exact problem to figure out if the problem is more likely with the battery or the alternator
Old 01-12-2019   #6
kjeldio has donated!
Denmark
Alternator alternator alternator ...
kjeldio is offline Reply With Quote Quote
Old 01-12-2019   #7
Why is it so echoey
Old 01-12-2019   #8
OK so someone I know has an old battery tester he tested the battery and the reading said Bad. Does this rule out the alternator being the problem?
Old 01-12-2019   #9
8v reading
Old 01-12-2019   #10
nikrox has donated!
Take the car to Halfords for a free battery/alternator test...you could also ask if the alternator belt is loose,or ask your mate.
Old 01-12-2019   #11
I would if I could start it lol
Old 01-12-2019   #12
nikrox has donated!
Does it not jump start?..
Old 01-12-2019   #13
Yes but struggling to find a good samaritan atm
Old 01-12-2019   #14
Belgium
Quote Originally Posted by Stace777 View Post
8v reading
Seems like it has been tested with a true battery tester, which compared to a volt/multi-meter DO drain a lot of current off the battery through a huge resistor. 8V reading clearly shows that the battery cannot afford that amount of current delivery, so is probably dead. We need more info...
- voltage at battery WITHOUT load, engine stopped: should be 12,6V (fully charged)
- voltage at battery WITH load (tester): shouldn't drop more than 2Vish (depend on battery capacity)
- voltage at battery with engine running @ 2000rpm: 14Vish
If those 3 are ok, your system is fine UP TO THE BATTERY/ALTERNATOR, so the issue is either in the cables or the connecting lugs (ground ground ground...).
The battery can still be good but the alternator (or a cable) gone bad; in this case you wouldn't read 14Vish with lights and rear defrost ON (this is to pull current off the alternator to check for resistive connection):
- With everithing OFF but the engine, little current is going from alternator to car, so there is limited voltage drop and you MIGHT read 14Vish at the battery terminals.
- With lights and defrost ON the current delivered by alternator will be higher, so will be the voltage drop in the resistive connection and the reading will be lower, even not enough to recharge the battery ...
BRs, Bernie
Old 01-12-2019   #15
It read 8v and 'bad' when the engine wasn't running
(T) Grande Punto - Battery light and power steering failure LesF Grande Punto 13 19-05-2018 12:10
(T) Power Steering, Battery, problem in 07 Grande Punto kev1ngav1gan Grande Punto 6 17-02-2014 00:44
(T) Power Steering/Battery light - Which alternator A sismithin Grande Punto 0 30-10-2013 11:53
Grande Punto Battery light and power steering problem! GazPatrick Newbie Central 4 04-09-2013 14:44
(T) New Problem (Battery + Power Steering) rich_lufc Cinquecento / Seicento 4 18-12-2008 17:09
