torniojaws
- May 4, 2019
- 137
- 40
Alright, finally I have all the gear and time to start replacing the front struts and links in my 2008 GP It still has the originals!
So, my first step was obviously to spray the pinch bolts with some penetrating fluid, in expectance of 11,5 year old nuts being wee tight...
But to my surprise, while my electric impact had some trouble (not really spinning it at all), I was able to get them fully loose without too much effort using a 18 mm socket and a 600 mm / 24 inch breaker bar. I mean, no tighter than any average nut or bolt! Was kind of surprised, but hey, awesome stuff Didn't try using the impact at max power though, it was at 2/5 to start carefully and not begin by breaking bolts.
I'm currently letting the penetrating fluid to soak in fully, to the links also, and then will continue.
I already assembled the struts earlier on and that was quite uneventful. I actually did them in my office room(!). Just compressing the spring with two lock-bolted spring compressors and a bit of elbow grease with a heavy ratchet. No real issues beyond beginner unthoughtfulness On the first attempt, the end of the compressor went inside the spring seat on the strut, so I had to use a second set to get it out :yuck: Must be due to being tired as it was close to midnight.
So, going to post more later, and I might make a quick amateur video out of the stuff I filmed. Mostly to cover some things that were kind of lost in a couple of professional videos I watched when planning, and also the OE numbers for all the parts, since I built the struts with all-new parts.
Here's by the way the best videos I found for an amateur like me. All of them are missing the OE numbers though, and even some torques
