Modify the wiring:
- the original set is with H4s right ? Those bulbs have TWO filaments: dipped and high beam. They also need ground to turn ON, so their socket has THREE lugs (connections).
Normally, yes, H4, but there is something a little different that I must mention in a quite big reply..
In Grande Punto, there is an 8-pin connector that plugs in from the car to the stock headlamps and aftermarket headlamps, that have this particular 8-pin plug:
________________________________________________________________
Check this video for around 15 seconds (I pointed out the minute it will start) to see the 8 pin wire that connects to the 8-pin plug I showed above:
[ame]https://youtu.be/dvDpkbVE4XQ?t=627[/ame]
Now, over here, see for 12 seconds where he removes the H4 bulb from its place:
[ame]https://youtu.be/dvDpkbVE4XQ?t=724[/ame]
What I mean to say by all this is that the car 8-pin wire (male) connects to the headlamp 8-pin plug (female), and from the 8-pin plug (female) there is a wire that has the the 3 pin connector for the H4 that we know.
- the blocks you want to install are built around two H7s right ? Those bulbs have TWO connecting lugs each (ground and positive for the only filament).
So the standard loom (harness / bunch of wires) will NOT fit the new blocks and either you'll have to modify them OR there is a providen extra loom that would convert the 3 pins socket into 2 individual 2 pins sockets (why they say "couple the wiring").
This is the exact moment when you would install the extra relay, whose task will only be to insert the diode in between both original relay's coils in such a way that the dipped relay is activated by the high beam relay only if the dipped light switch is in ON position.
No, not H7.. The aftermarket headlamps take H1 bulbs, but they still have the same 8-pin (female) plug the stock headlights have in order for the car plug (male) to connect to, as mentioned above.. That alone saves a lot of trouble I think...
In addition to this relay and the diode, you'll have to connect a capacitor in parallel (that's what // means) with the coil to keep it activated the time of transition between dipped and high beam (remember the dipped relay WON'T be powered anymore by the BCM). The capacitor value will depend on the relay coil size and its charging current should be limited by a resistor to avoid current peaks when you'd turn the dipped ON (and so charge the capacitor).
The extra relay will drive the dipped relay coil only so a single inverter or even NO contact 5A relay would be WAY enough, the coil needs to be 12V ...
BRs, Bernie
This too, is all plug and play? Also, the BCM won't recognize all this change, right? Also, if you can, can you please post pictures of the oil/relay and capacitor? I ask so I will understand it better...
