Yes, that's normal wear. But, how many pages this topic will be? Ten, twenty?
They've never put nutz back. That's it. Topic closed. Nothing to "investigate" here.
Weight of the car is pushing on those bolts, so depending on road conditions (how many bumps and turns you make), you could drive it for years.
Lesson for you and others too: check your car from time to time. As a basic check, maintenance. Bend over, get down on your f knees and look under the car, if everything's on place, no fluids dripping and so on. That's your "job" as a car owner.
Eight months, and you haven't looked at the wheels (and what's behind)? Do you check your tyre pressures?
Were there any signs, strange "clunking" noises from the suspension? I bet there was something. Or car pulling to one side ever so slightly?
Verdict: it's 95% mechanics fault and 5% yours (you don't care, you just put the fuel and drive the car, that's it).
Deep apologies. I will try to end this thread in a couple more posts maximum. Though, as you asked a question I will respond.
No, there were no clunking noises, no noticeable issues at all before this happend. And in some of the photos I have posted I have noted that the bolt that remained inside of its slot looks pretty snug in there, there is even dirt build up around the circumference of the bolt head which indicates the bolt hasn't been moving at all and is very secure inside. The other bolt was probably snug for a while and eventually slipped out.
I would hazard a guess that there were never any nuts placed on these bolts, hence no rattling. Once the top bolt came loose from its slot it would have fallen out pretty much instantly.
I was just after a significant piece of evidence that would pretty much nail this on the head that they didn't put the nuts on, or didn't screw them on properly. I am down £150 for getting a recovery vehicle to pick my car up and I was questioning whether to request/demand they cover this cost as right now I can't have 100% conviction it's their error.
I will go and speak to another local garage and get their opinion. I need to speak with them anyway as I'd like them to give the all clear on the work Halford have done and check the bolts on the other side.
I understand I have a responsibility to check my vehicle, but I am not sure I am legally supposed to check specific things like nuts and bolts of the wheel/suspension arm. I am legally required to have an MOT which obviously is a safety check, which ironically led to my vehicle being unsafe as it ended up with 2 important nuts not being secured properly.
If this accident had happend at higher speed and I veered off the road and someone died, would I be culpable?
An MOT centre, a garage should not be sending unsafe vehicles out again. Anyone sending their vehicle for an MOT should expect it to be road legal when they get it back. That's the whole point in it.
All the vehicle checks I have googled about that is expected of car owners talk about 10 basic checks. Feel free to link me to a website which shows all the checks us car owners are required to do. I would be interested into how much detail we have to go to.
