Old 09-10-2019   #1
Cruise Control Fuse Location Help!
hello i've spent the past hour searching the forum and the internet and cant find my answer so i will now start a new thread and ask on here my cruise control has not worked since i have bought my 2008 fiat punto grande sporting 1.9 multijet
the light on the dash doesnt come on and i have been trying to figure out why i keep reading on multiple other posts about a fuse for cruise control but after looking online and in my owners manual cant find a fuse for it so if there is one could someone tell me which fuse it is. and if not i have also read about connector in engine compartment and under the steerign heel near the steering column. if thats the case could someone describe in slightly more detail where these connectors are or even send a picture of the connector so i can also check those thanks
kristianulusan is offline Reply With Quote Quote
Old 10-10-2019   #2
Belgium
Re: Cruise Control Fuse Location Help!
Is your cruise control part of the original equipment or is it an "add-on" ? To my knowledge there is no specific fuse for the cruise control ...
BRs, Bernie
Old 10-10-2019   #3
kjeldio has donated!
Denmark
Hi!
It dosn't need a fuse, it's using the "drive by wire" function allready there, but check the function of the clutch and brake pedal switches, (search the forum) sometimes they are only bad adjusted.
BRs. Kjeld
kjeldio is offline Reply With Quote Quote
(G) fuse location junk Ducato 5 18-12-2015 13:43
(T) Retrofit Cruise control in my stilo WITH cruise control light Daveystrings Stilo 30 25-09-2013 21:05
(T) Fuse Location reveds1969 Stilo 5 28-12-2008 20:13
(T) Fuse Location Jamie Grande Punto 10 19-11-2007 23:05
(T) fuse location gavink@iolfree.ie Punto (Mk2/2b) 4 19-05-2004 04:47
