I wonder if I can ask for your help.
My 2006 GPS 1.4 8v is suffering from water ingress into the rear light clusters - left one regularly has water sloshing about after periods of rain and now the right cluster has condensation inside it.
I know about the tailgate boot issues of split cables and split rear washer fluid feed tube as well as the tailgate shower.
I also have this issue which is waiting to be fixed but I haven't used my rear washer for about 8 months since investigating a non functioning indicator and finding the connector stained windscreen fluid blue.
My questions are;
1. Has anyone found how rainwater is getting into the light cluster unit?
2. How did you fix it? The water ingress and not just drilling a hole in the light cluster to let the water drain out.
I understand how washer fluid from a split tube has a direct path down the wiring loom through the connector and into the light cluster unit. If you're unlucky might also cause a short and half melted pin - like on mine.
But I haven't used my rear washer for ages since finding the split feed tube and the water is freshwater.
The square 'seal' (I use that term lightly) around the connector area which presses against the hole in the body when the light cluster is fitted is in good condition without any signs of water damage/penetration.
The rectangular rubber 'o-ring' (again I use that term lightly) around the bulb holder which presses against the cluster shell when the bulb holder is screwed in place is also in good condition without any damage or signs of water damage/penetration.
There is a gap (1-1.5mm) at the top between the front and rear sections of the cluster shell where presumably the two halves are joined/moulded together. But this is only about 2cm long down the side before both halves are smooth and consistent to the bottom.
With the light cluster fitted the drainage channel down the sides of the tailgate opening is almost non-existent and in medium to heavy rain the water will run over the side tab of the light cluster where the mounts are. But if there was a blockage high up which pushed water behind the light cluster I don't see anything which would give it a sideward path toward where the bulb holder mounts into the light cluster shell. Gravity would deal with it sufficiently.
The only possibility is if the area around the bottom of the cluster & body was completely blocked and the water flow was so heavy to cause water to build up completely filling the rear cavity and the pressure pushing it through the rubber 'o-ring'.
Next sunny day I will be investigating this 'gap' further at home with a sink full of water.
I know drilling a hole will let the water drain but it won't help with the condensation.
I've never experienced so many issues in the first 12 months of owning a car before and I'll put that down to bad luck rather than it being a Fiat...
Thx,
Mark
My questions are;
Thx,
Mark
