Thanx Jock. I,m not loosing coolant and temp gauge never exceeded half. My system on Punto III has no radiator pressure cap, I think that pressure is regulated through cap on water reservoaire tank. But I checked also radiator hoses today on my Fluence 1.6 and both are soft too...maybe little bit more firm than on Punto. I'm still thinking about possibilities of my "engine ticking issue on hot engine" and I checked valves, oil passages, cleaned oil holes, checked valve clearances, cleaned valce cover. Everything OK). So I thought what if there,s air in radiator (isn't), so I checked hoses temp by hand when engine reached operation temp...but temp of upper hose from thermostat increased slowly, and hose was very soft. Thats why I thought that thermostat keeps opening, but it stuck somewhere in the middle. I thought that engine isnt cooled properly and that can cause that ticking...I'll check it more precisely... Because I found infos that sometimes, even cooling system is overheated, temp gauge shows good value... And I don't want to remove thermostat to check it at home in boiling water...1st I needed to know if radiator hoses are soft or hard when termostat is fully opened. I saw other vids on YouTube and guys were able to press hoses by two fingers too...But I'll check it also with laser temp measurement tool. Plus - when I checked hoses to radiator and they had appr 60-70 degrres of Celsius, fan starts blow for few seconds. Thats another indication that maybe my termostat isnt opening fully. And engine was overheated by previous owner, and it maybe could damage thermostat...
