Hi guys, I’m sorry about this post because This problem I’ve got
Is a common problem with the GP
The boot lock has stopped working today, I think I’ve found the issue but I could be wrong,
the reading ive got from wiring connector using a multimeter (disconnected from the lock mechanism)
Pin 1 12.7v
Pin 2 (boot light signal) - This works
Pin 3 negative
Pin 4 0v but I get 12v when I press the button on the dash or fob to open)
I’ve tested the negative wire by doing the following, I connected the multimeter black wire to a ground on the car, then connected the red wire of the multimeter to pin 3 and checked continuity, and there wasn’t an open line, so am I correct to say the negative pin is fine?
Pin 2 works fine for the boot light,
Here the problem, When I connect the wiring connector back to the lock mechanism I get the following, (I’ve taken the cover off the lock,
Pin 1 12.7v (lock in closed position)
Pin 2 works for micro switch
Pin 3 Ground
Pin 4 is also giving a ground like pin 3,
I’m no auto electrician so electrics ain’t my thing, but does this sound like the pins 3 & 4 are shorting out when connected to the lock? Because when connected there no 12.7v on pin 4 when triggered with fob or dash button to release boot,
Hope I make some sort of sense
Chris
Pin 1 12.7v
Pin 3 negative
Pin 3 Ground
Chris
