marksalmon
- Jul 20, 2019
- 7
- 2
I'm trying to replace my rocker cover gasket and I'm hitting the problem of not being able to remove the rocker cover.
I've removed the air box, loosened the cam (or timing belt? - cant remember which) belt cover, removed the coil pack, removed the earth connector and i've pulled the ECU bracket away BUT I'm having no luck with getting the rocker cover off. I have the 8mm bolts from the rocker cover removed too.
Any suggestions? Are there any extra bolts that need removing?
Its a 2009 1.4 8V Active Sport.
