On Saturday afternoon treated the car to an oil change, gearbox top up and reset dpf counter. Every year I see a pipe that is gradually corroding and have it on my furniture to investigate list. I am aware of a tiny bit of coolant loss. As I fitted the undertray back I noticed a bit of water under the radiator but as it has been raining brushed it off.
This morning went out on my bike, small puddle at the front left as you look from the front of the car, distinct paraflu hint of colour, so I accept I have a leak. I assume it is from the radiator and running it’s course to the lowest part but what is the big metal pipe maybe 3/4 inch diameter which is basically level with the bottom of the radiator and behind the bumper and slam panel, it looks like it is part of the intercooler pipework, if so I will remove and repair as needed if it just air inside, if it rusts through though where do the bits go and what side of the filter are they, Eper doesn’t cover my car and I can’t see the pipe for sale anywhere.
It is metal large in diameter and tomorrow after work I shall investigate the leak further, the radiator doesn’t seem expensive and I’m assuming the water is just running over the pipe I’m talking about possibly adding to the corrosion of it. I’m asking with out all the info but I will strip it tomorrow and if required stick a pic of the pipe on here, thank you.
