- Dec 23, 2014
- 778
- 198
Just towed my friends car home. She was reversing when ,without warning she felt something go 'ping?' and hey presto no gears.
No side to side movement in the gear lever,no friction going from first to second...and its stuck in reverse gear.
Clutch res is full,no leaks anywhere and the clutch pedal feels normal.
Slave cylinder is dry too..not a lot of movement in the arm tho..but then again I dont know how much there should be.
I took the gear lever cover off,tried to engage reverse and theres nothing connecting the bush that slides up the pillar of the lever.Some plastic bit did fall out.
Any one got any ideas?..please..
