Just an update if anybody else in future has same problem, I started to get some judder when pulling away in 1st and reverse when lifting the clutch up, it’s the same judder you get when the clutch is starting to go,
I strongly thought I would have to get the clutch changed. But I read a thread on here regarding clutch issues and the stages to try before changing the clutch,
One was to change the fluid, so I finally got round to flushing the slave cylinder using a self bleed kit, it was easy tbh, just turn the bleeder anti clockwise but make sure you put some tubing over the nipple into a container. I flushed through 500ml fluid just to make sure any old fluid in the clutch system was gone, I have to admit the old fluid looked clean But I did notice there was quiet a lot of air coming out with the fluid then just a Constant stream of fresh fluid, So my problem must of been trapped air in the system somewhere
Test drove the car and it a lot better pulling away and gear changes are a lot smoother, Really Appreciate all the info given ?.
