You need the extension leads on the multimeter test ports. They're very useful when testing longer wires. On the other hand multiecuscan (mes) diagnostics would be able to show canbus errors which are not accessible by general obd tools.
It may very well be related to the door wiring inside the rubber sleeve or it's bcm failure which would be very expensive and not worth fixing.
Finding each pin on the connectors is another chore, usually pins are numbered inside the connectors.
