im Axle Specialists
Old 12-06-2019   #1
map sensor and boost pressure sensor, fault codes
hi all, im recieving the following codes from diagnostics: P0235 and p0069.
Turbocharger (TC) boost pressure sensor A/supercharger (SC) boost pressure sensor A – circuit malfunction. (P0235)
Manifold Absolute Pressure - Barometric Pressure Correlation. (P0069)
everywhere iv'e read has said to change the boost pressure and the map sensor. the trouble is, i already have. which is a problem as i would really rather not keep going around in circles. i was wondering if you could offer any advise on what to do as i am at a loss. ill give a list of things that ive changed to try give an idea as to what is new and what isnt. many thanks, cam
new parts
MAP
MAF
EGR
FUEL FILTER
BOOST PRESSURE SENSOR
parts on order, coming tomorrow
Valve, adjustment element (throttle flap) OEM: 46754960
Its not broken, it's just full of character
limpyjet is offline Reply With Quote Quote
Old 12-06-2019   #2
Belgium
Re: map sensor and boost pressure sensor, fault codes
what engine ?
Old 12-06-2019   #3
When you clear the faults,does the car drive normal till you put the engine under load ?
multipete is offline Reply With Quote Quote
Old 12-06-2019   #4
Quote Originally Posted by Bernievarian View Post
what engine ?
1.3 mjt 90
Old 12-06-2019   #5
Quote Originally Posted by multipete View Post
no. it runs in limp mode.
or it will run until under load and fall into limp as soon as its in turbo range.
it varies every time.
Old 12-06-2019   #6
Check the waste gate on the turbo,get a screw driver or bar, and gently open and close the waste gate. Mine jammed under load,freed it off as above and still good 9mth later. May not cure your fault,but it’s free to do.
Old 12-06-2019   #7
been there, tried that im afraid. it was freely moving :/ thanks for the response though
Old 12-06-2019   #8
Belgium
I asked what engine, 1.3mjt is not enough, 75 or 90 bhp ?
Old 12-06-2019   #9
nikrox has donated!
He said 90...
Thanks Bernievarian thanked for this post
Likes limpyjet liked this post
nikrox is offline Reply With Quote Quote
Old 13-06-2019   #10
Belgium
Quote Originally Posted by nikrox View Post
He said 90...
Oooops!
90hp means turbo with variable geometry. This is done by moving a plate inside the turbo via a vacuum actuator, itself ECU controlled by an electro-valve.
When this fails the boost pressure gets so high that the ECU goes in limp mode. No need to replace MAP, MAF etc. Just inspect this VariableVaneTurbo system and fix it, I bet for a broken vacuum pipe...
BRs, Bernie
Thanks limpyjet thanked for this post
Likes limpyjet, nikrox liked this post
(T) Manifold Pressure Sensor (MAP sensor) repeated failures Powellj3 Panda (2012+) 3 01-07-2017 15:36
(T) 54 plate boost/MAP sensor?? Beefman27 Punto (Mk2/2b) 5 22-03-2017 15:50
(Tu) Pierburg MAP Sensor and Boost Gauge . Shadeyman Stilo 7 19-08-2012 06:27
(T) Air inlet temp sensor/boost pressure sensor robjames3 Bravo 0 25-01-2012 15:53
(G) map sensor and boost sensor CNapperturbocrazy Grande Punto 7 09-01-2011 21:57
