Technical 2009 grande punto
don4001
HELP HELP HELP
car says Fuel cut off unavailable had mobile diagnostic on it today dont think he really understood the fault tried resetting with the indicator stalk but to no avail can anyone shed any light on this engine seems to be immobilised :mad::mad::mad:
cheers Don
HELP HELP HELP
cheers Don
Hi Dom.
Tell us more.
What happened?
What does the dash show now?
Both keys doing this??
Charlie
Hi Chalie only got the 1 key
all display as usual but when you go to crank display says fuel cut off unavailable and wont turn over
car not been in an accident was driving ok until sat evening and just cut out with above message
Maybe the fuel cut-off switch has been triggered for some reason? Try to reset it...
BRs, Bernie
yes stopped when driving
all lights on dash going out as should warning yellow triangle in middle of dash?
when you go to turn over nothing as if battery was flat but fully charged
Hi Bernie
is this reset by doing the indicator stalk thing? or is there a switch/button to press ? im at a loss with this now
cheers Don
Hi Don,
the switch is located in/near the A-pillar (left one on LHD, not sure on RHD...), it shuts off the primary fuel pump (in the tank) in case of crash, and probably the engine too.
BRs, Bernie
Had 3 mechanics out to this all tried different things I couldn't even find the switch tried the thing with the indicators but nothing
Hi Don,
BRs, Bernie
According to the handbook (page 55), there's no switch and it's a sequence of indicator activate/deactivate, which the OP has tried and hasn't worked.
