im Axle Specialists
Old 21-05-2019   #16
Re: 1.3 multijet (90) turbo issue
Quote Originally Posted by Pugglt Auld Jock View Post
Here's a couple of videos which will help you understand what is probably going on with your variable vane turbo. This exact problem (stuck vanes and overboost) happened to my boy's Fabia 1.9 PD. We managed to clean it out by dropping the exhaust pipe off the turbo and using a can of foaming oven cleaner injected inside to clan out the carbon deposits. We did 3 applications leaving about 1/2 hour each time for the cleaner to dissolve the carbon and flushing out with the garden hose well each time before refitting the exhaust. the car ran fine for the next 3 years when we sold it - it was still going well at that time.
https://www.youtube.com/watch?v=CbdY1rymBJg
https://www.youtube.com/watch?v=o1Hvt2b7PL0
The variable vanes are there to spin up the turbine wheel at low engine revs thus reducing turbo lag, then as engine speed rises - and so exhaust gas volume increases - the vanes deflect so that not so much force is applied to the turbine. If the vanes jam it's usually in the resting (so max boost) position which is why you get limp due to overboost.
Have a look on you tube there are lots of videos posted - that's where I learned about using the oven cleaner. Other, dedicated, products are available.
If you decide to have a go yourself It's a mucky job and the oven cleaner stings a lot if you get it on your arms - definitely wear goggles! Good luck
firstly thank you for the videos, that second one explains perfectly what is going on.
as to the advice on how to free the vanes, ill try that if all else fails. i dont want to pull the turbo off and find out it was just the vacuum pipe!
thank you for the response, Cam (limpyjet)
Likes llamallama liked this post
limpyjet is offline Reply With Quote Quote
Old 21-05-2019   #17
Australia
Yep,
I think I got a bit of play in my turbo ay,
I'll be checking that on the weekend
Thanks limpyjet thanked for this post
llamallama is offline Reply With Quote Quote
(T) 1.3 multijet issue aposegil Doblo 1 18-04-2018 22:58
(T) multijet issue seanoo Panda 7 28-04-2017 00:22
(T) Power steering issue with 56 1.9 multijet Se7enHP Grande Punto 1 08-07-2016 16:07
(T) 1.3 Multijet will starting issue! Confusing one!! mikedoblo Doblo 21 29-03-2014 08:18
(T) 06 1.9 Multijet electric window issue MickDev Stilo 2 02-04-2012 22:25
